It may be hard for some gardeners, in particular for the novice ones, to determine exactly when to harvest cucumbers. There are a few visual signs and scales that will tell you the right time. And these signs are as follow:
Right in Size
Not like other fruits, cucumbers stop to mature after picking. The fruits require an extended growing period and are ready to pick in fifty to seventy days. If you harvest ripe cucumbers at the exact time, rest assured that it will only give your throat a sweet taste.Harvest the fruit when you know it is already right in size (which is typically 8 to 10 days after the earliest female flowers open).
Color and Firmness
You’ll also know a cucumber is ready to harvest by its color, firmness, and size. When planting the vines, ensure to read the seed pack or plant label. It must consist of a precise measurement of how long the vegetables will get. Also, the seed pack or plant tag will indicate the number of days you can pick the cucumber after germination.The climate condition also affects the vegetables’ growth rates, so you may find the harvesting period not exact. When you softly squeeze the cucumber, it must give you a firm touch, plus the color should be a good medium to dark green. The color depends on the type of variety you’re growing. A yellowish or white shade may occur to some cultivars.
It is best to pick the cucumbers as early and often as possible, so the vine will be encouraged to produce longer during the season. Do not allow the vegetables to become over ripe. Also, do not leave it on the vine for a longer period; otherwise it will develop a harsh taste. The cucumbers become fully matured at different times on the vine; hence it is important to harvest them as they’re ready.
Length
For those who are asking when to harvest cucumbers prickly for making gherkins or sweet pickles, they must be 2 to 6 inches long.Dill pickles are best to harvest when they’re already three to four inches long. Burpless varieties are ideal for picking at 1 to 1 and 1/2 inches in diameter, while the slici
ng cucumbers should be harvested if it’s already 6 inches, depending on the variety.You are likely to pick the fruits every day or two in the peak of the season. It is suggested to harvest it early in the morning when the vines are still cool.Now that you know the visual signs and scales of accurately picking the cucumbers, the next concern that may be arising into your mind is how to harvest the fruits.
Share from: https://www.leekgarden.com/when-to-harvest-cucumbers/
