My camera is running really hot. After about 5 mins it’s hot to the touch and the image drops and I have to unplug it. Once it cools down I can plug it back into the USB and it works again…
It seems a little intermittent and might be somehow related to the light adjustment resister mounted to the USB plug.
When I turn it from off to full brightness, it gets kind of stuck about 1/3 of the way, my finger usually slips off the trim wheel and then I can push it past with a little more effort and I believe the LEDs go to full brightness as they are very bright.
No direct relationship can be consistently recreated but somehow adjustment seems to make a difference when cycled… The time it takes to overheat therefore can be longer or shorter but isn’t in direct relation to the position of the resistor.
I opened the plastic USB casing and it would appear that at least one ground isn’t soldered to the PCB and there appears to be a couple cold solders as well, all associated, I believe, to grounding pads…
OH, and my switch seems to be COMPLETELY MISSING…
J/K
(Actually it IS missing, but you understand…)
