With the newer release candidate versions (RC5 RC6 RC7) I cannot run the previous sequences I added before, I even created simple ones (turn on lights wait turn off lights) but they are not running. The website is still telling me that the sequence was successfully sent to the rpi. I tested both on staging and my.
I can still use the controls perfectly (movements abs/rel and peripherals)
I can run controls and sequences. I turn off a led on pin 10 and 9 using the controls. I can run the y motor in the sequences tab. I have tried to take that sequence and put it into a regimen called “y Motor”. I am having problems setting and keeping the time to run. Is there some sort of wild card that I can set the time with and test things out?
My api is 783b432 and front end 43956d4. Is this the latest that I should be running?
I look forward to the kit. my inside spring planting is gone. We have a 90 day June to Aug. outside growing season.
