Hi,
We are trying to connect the farmbot. I flashed rpi to the sd card, and I am not able to find farmbot’s Wi-Fi on my PC, so we can connect it and reconfigure.
Kindly let me know about any solutions that are available for this matter.
Hi,
Which FarmBot OS version did you flash to the SD card? Is the Raspberry Pi’s red LED on and green LED blinking? It’s possible that the FarmBot OS .img
file did not successfully flash to the SD card.
Hi Gabriel,
We’ve used the raspberry pi rpi 6.4.9 which is the latest OS. the green LED was blinking. DO you suggest we repeat the flashing process once more?
