[Farm Designer] Select multiple plants
If I want to change the plant status, I need to click on every single plant. Would it be possible to ctrl + click to select multiple plants and thus change the plant status?
I too would like this feature!
The problem is bigger than just that!
Farmbot needs to introduce group operations in general
  • create multiple plants in the designer
  • update/delete multiple selected plants
  • execute sequence(s) for multiple plants matching certain criteria
In meanwhile you can try to use my farmware “Seedalot” and “MLH” - first one creates multiple plants and second updates plants and run sequences.
But I’d rather use standard solution for this.
Thank you,
Eugene
