Hi all, would it be possible to call up a Farmware via MQTT?
Yes, you can do that quite easily using the execute_script
Celery Script node, by sending the command as you would any other over MQTT. This is the node the Run Farmware
sequence step uses.
In Python:
import json
import paho.mqtt.publish as publish
# Prepare the Celery Script command.
command = {
'kind': 'execute_script',
'args': {'label': 'My Farmware'}}
# Send the command to the device.
publish.single(
'bot/device_1/from_clients',
payload=json.dumps(command),
hostname='brisk-bear.rmq.cloudamqp.com',
auth={'username': 'device_1', 'password': 'my_token'})
How silly I am I could have figured it out myself… thanks Gabriel
Is there an “easy” way to setup my own MQTT broker to feed the PI (bot) with my own commands directly?
In the on-premise installation of the my.farmbot.io software I saw that it installs RapidMQ.
I like to replace this with my broker (if possible).
What I would need is:
how to change the MQTT “Hostname” in the PI?
What are all the possible topics/payloads the PI is expecting (I assume its documented somewhere but the code is quite large:))
Thanks,
have a look here https://farmbot-developers.readme.io/v6/docs/message-broker and search for MQTT in the forums. there is at least one thread about it.
If you need more help, come back
