Hello, i can´t sync my farmbot and i had changed all , even i flashed the SD but all is the same.
when i try to configure my farmbot, i get the message …Farmbot is stoping the hostapd
i think the the server is down, what could i do?
If you follow all steps properly and still cannot sync your farmbot this could be due to your wifi signal, firewall or company/country. For example some countries like China are blocking the connection between the Farmbot and farmbot.io
In that case you’ll need a VPN router.
