Any edits you can suggest? I have tried exporting from a copy of the project - but the image looks fine to me. Would the “All Plates Layout [Flat]” drawing be the place to edit or is it compiled from another file somewhere?
Any chance you could share a working version the file (is there a way to do that here)?
That’s a very odd issue, but if you delete the plate that isn’t uploading to Big Blue Saw correctly and add it again using the left face, it should work. I can’t edit the v1.1 drawing, but I edited the current workspace drawing here. However, because that is the current workspace, it may break at any time due to ongoing changes.
Another option is to replace the offending plate with a copy of the one next to it (it’s the same plate) with your favorite DXF editing software (you can edit imported DXFs in OnShape).
Skynet, did you ever get your plates cut from Blue Saw?
I sent them STLs, which they told me to convert to DXFs - but I’m not able to find an option in OnShape to export to DFX. How did you get your shapes to Blue Saw? Are you able to share your cuts with me? Like you, these plates and the motors are the last items I’m needing to purchase for my farmbot.
If you want to export individual plates instead of using the drawing with all the plates organized for cutting linked to above, you would have to go into the part studio for each plate, right-click the face of the plate, and click “Export to DWG/DXF”, then select “DXF” as the file type.
Otherwise, you can just export the “all plates” drawing by right-clicking the tab and selecting “Export”.
It’s in the OnShape document. Here are a series of screenshots that may help you out, but I want to reiterate, it’s best to simply export the drawing with all the plates in it if you don’t need individual parts.
