Everytime I execute a farmware or sequence I get a log entry:
Something went wrong: (‘Connection aborted.’, BadStatusLine("’’",))
This is VERY consistent right after the first step in a sequence and VERY fatal during watering as this is not causing the robot to go in e-stop and the water valve stays on!
Here is a log from Farmbot from today:
Farmbot sent you an email.
Here’s what your device had to say:
- [MLH] Something went wrong: (‘Connection aborted.’, BadStatusLine("’’",))
- #Farmware<MLH(1.1.4)> completed with exit status: 1
- CS Failed: [execute_script] - “Farmware failed”
- Bot is Successfully unlocked.
- Moving to (210.2, 218.6, -199.96)
- Movement to (210.2, 218.6, -199.96) complete.
- Moving to (110.2, 218.2, -199.96)
- Movement to (110.2, 218.2, -199.96) complete.
- Syncing
- Synced
- [Water All Planted Plants] - Sequence init.
- [Water All Planted Plants] - Sequence Executing: SendMessage
- FarmBot is at position 110.4, 218.2, -199.96 and starting to water
- [Water All Planted Plants] - Sequence Executing: ExecuteScript
- Beginning execution of #Farmware<MLH(1.1.4)>
- [MLH] {‘save_meta’: None, ‘min_x’: 110, ‘default_z’: -200, ‘sequence’: {‘init’: {‘name’: ‘None’, ‘id’: -1}, ‘after’: {‘name’: ‘water for 30sec’, ‘id’: -1}, ‘end’: {‘name’: ‘None’, ‘id’: -1}, ‘before’: {‘name’: ‘None’, ‘id’: -1}}, ‘filter_meta’: [(‘plant_stage’, ‘planted’)], ‘action’: ‘real’, ‘pointname’: [’*’]}
- [MLH] 142 plants selected by the filter
- [MLH] Moving absolute: {‘y’: 80, ‘x’: 150, ‘z’: -200}
- Moving to (150.0, 80.0, -200.0)
- Movement to (150.0, 80.0, -200.0) complete.
- [MLH] AFTER: Executing sequence: water for 30sec(8090)
- [Water for 30sec] - Sequence init.
- [Water for 30sec] - Sequence Executing: WritePin
- Water turned ON
- [Water for 30sec] - Sequence Executing: Wait
My connection to the site and is looking good without any disruptions:
RASPBERRY PI INFO
CPU temperature: 47.2°C
Diagnosis
All systems nominal. (code 31)
Can anybody investigate on the “BadStatusLine” issue?
Thanks
Chris
