[Log] content additional requests
Could you add a message (with whichever classification, it doesn´t matter) if the FB was stopped due to encoder problems and tries again? Currently I cannot see this from the logs or where would I need to look at?
Moreover it would be very cool if you could get sensor readings a separate flags. Otherwise this is quite some searching effort if they are all labelled as info and you need to browse through them in order to see sensor readings…
