My FarmBot does not respond to the movements I send.
It does not make any movement.
I already do the electrical checks and everything is fine.
HELP!
Can you provide us more information:
- Have you installed FarmBot OS and configured it?
- Has the FarmBot ever come online before? Please share a screenshot of the connectivity widget.
- Have you been able to send the bot other commands? Or were movements working in the past and they suddenly stopped?
Hello there, im having the same problem here.
Ascend
Split this topic
4
5 posts were split to a new topic: Bot does not connect / Open ports
@roryaronson
Our bot is not responding the commands, it dont move.
Just take pictures.
Ascend
6
@mmileme2018
Could be a few different things:
If you don’t see a green bar in your connectivity widget like this -
- Arduino/Farmduino is not properly connected to your Raspberry Pi
- Arduino/Farmduino is not properly connected to your power supply
- Try to reboot and see if any LEDs of your Arduino/Farmduino is flashing
- Also check if the Arduino/Farmduino is connected to the power supply (12V).
