Recently i started learning about Farmbot and i started to use the real time boards to work with the web application for executing sequences along with some sensors getting it sensed and actuated with respect to the sequences. And suddenly the Pi it is getting connected to the configured Wi-Fi and gets disconnected within 30 seconds like before the web application is getting synchronize, this Raspberry Pi gets disconnected. I checked the power supply, tried with a new SD card, tried with a new cable. What is likely to be happening in this case and what would be the solution?
It’s hard to say without seeing exactly what is happening but i suspect that your WiFi signal is not strong enough. Have you tried using ethernet as a test?
