Hi All,
Is there (or will be in the future) diagram or files provided for UTM v1.4 PCB?
Another question is what are the diamaters for Pogo Pins used in v1.4?
MS
Hi All,
MS
A CAD model can be found by clicking the UTM link at cad.farm.bot. The diameter of a section of the pogo pin will be shown in the lower right of the screen after clicking on that part of the pin.
Hello skuter, Hello Gabriel,
Hi @all.
I’ve similar questions. Are there PCB-files (Layout) for the UTM 1.4 for example as a “PcbDoc” or eagle or gerber or similar -format available?
A second question is about the “Pi Adapter Board”-PCB: We like to buy this PCB in your shop, but there was no possibility (same like UTM-PCB). Do you document the PCB-Files (in “PcbDoc” / eagle or similar format) for the “Pi Adapter Board”-PCB anywhere? How or where can we get this files ?
I remain
with best winterly wishes for your team and with kindly regards from Saxony
Michael
IF you need choose Pogo pin Diamaters,Maybe this info will help you
Below is Cnomax pogo pin Connector Catalogue for your REF.
2.54mm-Pitch-pogo-pin-connector-Catalogue
