What materials are you using for the 3D printing parts?
PLA or ABS will do. But ABS is better for the outdoors.
I would advise against using PLA. It does not hold up well to UV rays and becomes brittle. Itβs also plant-based and can be degraded by water over time. ABS is used for a lot of car parts that are out in the sun constantly, and it also flexes slightly and is less likely to break than PLA.
