As a proof of concept, I want to assemble FarmBot as much as possible before migrating to another country. I don’t want to build it on a planting bed, I just want to build it on the floor of my attic.
I need some pro tips to do this. I wonder how harmful having no support structure beneath the tracks can be. How can I provide the required infrastructure with minimal effort?
I was thinking just making a tiny wooden frame (1.5m*1.5m) to mount it on top. The frame would just be lying on the floor.
Wood size: 1thick x 2-inch wide x 8ft long
that’s a total of 5, 8ft long planks cut down to 5ft each. Two of the planks run verticle (along the X axis) and the other 3 are represented by the red lines that run horizontal to the X axis planks.
Drill through the 2 wood pieces so you can insert the bolt into both planks.
Bolt all of the corners down with 3-inch bolts and extra wide (1inch) washers on top and bottom of the bolt and the appropriate nut size.
