all the time I’m trying to calibrate my camera when I click on “calibrate” I just get the little popup message at the bottom of the window “Failure : Camera calibration failed”. There is no Error Message in the log no nothing.
Anyone got some hint on how to fix this? I just followed the documentation. These are my settings:
if your settings are right, after scan image, you’ll have 2 areas highlighted in a new image - i.e. your markers. In case scan did not recognize the markers (nothing at all, or more areas which are not markers etc), you need to play with color setting above the image. basically you set a color filter to match color of your markers.
markers on your photo seem rather bright, I would try with another photo with less brightness…
