Greetings I have a connection problem when I try to enter the program from other networks, someone else has this problem or knows how to solve it.
If I understand your question correctly (i.e. it is the Farmbot itself that you are trying to connect to a new network), I would suggest:
- Re-flash the SD card
- Re-connect to Ethernet or Wifi through the usual procedure
- Re-flash the firmware
- Restart the firmware
It should be quicker than trying to troubleshoot the underlying issue.
@oscar Can you provide more information about:
- What the connection problems are- can you connect at all? Does it disconnect sometimes? What does the connectivity panel look like?
- Which program are you using- Is the problem in the Web App, or in the network configurator?
