I’m trying to help our students and seem to be running into issues.
We have enterprise wireless with Meraki APs but can’t seem to get connected.
If we use WPA2 with a pre-shared key, it immediately deauthenticates as if the password is incorrect. We have checked the password and have even reset it with the same results.
If we use a completely open network (not appropriate for our school), it does show an initial connection but the status never is updated in the dashboard and it in 5 minutes or so resets.
FarmBot doesn’t currently support enterprise wireless networks. Users have been working around this by setting up a wired network connection to FarmBot in these situations.
I suspect that there is a blocked port for one of Farmbot’s external services. Check this out.
Thanks.I mentioned enterprise wireless but we aren’t really using EAP or radius servers for this SSID. Just a simple pre-shared key that seems to be rejected.
I have reviewed that document but I would expect at least a connection showing that it is alive. It doesn’t stay connected. 80 and 443 are very unlikely to be blocked.
Has anyone found or create a good test for ports outside of the Raspberry PI?
