Aloha Folks,
Our Farmbot has started spitting out the following error and remains disconnected. I’ve tried cycling power but this did not help.
Any clues on how to get our bot back online?
Token Refresh failed: {%Sqlite.DbConnection.Error{connection_id: nil, message: "database or disk is full", sqlite: %{code: :full}}, [{Ecto.Adapters.SQL, :struct, 8, [file: 'lib/ecto/adapters/sql.ex', line: 554]}, {Ecto.Repo.Schema, :apply, 4, [file: 'lib/ecto/repo/schema.ex', line: 547]}, {Ecto.Repo.Schema, :"-do_update/4-fun-0-", 14, [file: 'lib/ecto/repo/schema.ex', line: 292]}, {Ecto.Repo.Schema, :update!, 4, [file: 'lib/ecto/repo/schema.ex', line: 136]}, {Farmbot.System.ConfigStorage, :update_config_value, 4, [file: 'lib/farmbot/system/config_storage/config_storage.ex', line: 175]}, {Farmbot.Bootstrap.AuthTask, :do_refresh, 0, [file: 'lib/farmbot/bootstrap/auth_task.ex', line: 41]}, {:gen_server, :try_dispatch, 4, [file: 'gen_server.erl', line: 637]}, {:gen_server, :handle_msg, 6, [file: 'gen_server.erl', line: 711]}]}
