First of all, I’m using the latest farmbot OS and the version 1.2 (Arduino/RAMPS) setup.
I’ve been trying to create a sequence to use the soil sensor and another one to check whether there is a mounted tool or not. I already used this features in the past but, to my surprise, every time I try to read the value, the farmbot turns into E-stop mode.
I have checked the wiring and the connections are good. I have also tested the feature without the pins connected to the RAMPS and it still turned into E-stop mode.
I have also measured the (V) values and everything seems reasonable.
Do you have any hint/idea of what the problem could be or what else I could test?
Does this error appear if you read the pin value manually in the Controls page or when running a sequence with a READ PIN step? I wasn’t able to reproduce the error yet.
To my surprise I was about to test the feature again and it worked. At least it didn’t get into E-stop mode.
Unfortunately I don’t have a screenshot of the log page and I can’t take one since now I can’t reproduce the error
So before it got fixed, I created two sequences for reading the value of the soil sensor and to check whether there was a tool mounted or not. I didn’t test the option to manually read the values from the controls page.
If I get this error again I would make sure to take a screen capture of the log page. Sorry for the inconvenience.
