In my farmbot designer, the UTM is moving in the wrong direction. Instead of going inside, it goes outside the farm as per the attached image.
Please advice on a solution.
I found out the issue was that the Zero Y position was wrong.
Any idea what causes the FarmBot to automatically the Zero Y position?
Your encoders are enabled right?
Farmbot usually does not zero any axis automatically, only if you would run a sequence that contains “Find home”.
Yes, I am using the encoders. I did not use the “find home” option either.
