But how come then that I can still control it and it does not say it is offline?
Success |
Synced |
0, 0, 0 |
Sep 24, 10:14pm |
3 |
Busy|Read peripheral (8 - digital)|0, 0, 0|Sep 24, 10:14pm|
|3
Busy|Read peripheral (9 - digital)|0, 0, 0|Sep 24, 10:14pm|
|3
Busy|Read peripheral (10 - digital)|0, 0, 0|Sep 24, 10:14pm|
|1
Debug|Synced Farmbot OS and Firmware settings with API|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating: sequence_complete_log => false|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating: os_auto_update => false|0, 0, 0|Sep 24, 10:14pm|
|1
Busy|Syncing|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating: network_not_found_timer => 30|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating: auto_sync => true|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating: arduino_debug_messages => false|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_missed_steps_max_x: 5.0 => 10|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_axis_nr_steps_z: 0.0 => 3355|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_stop_at_home_y: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_missed_steps_max_y: 5.0 => 10|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_use_for_pos_y: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_stop_at_max_y: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_5_time_out: 0.0 => 60|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_enabled_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_step_per_mm_z: 25.0 => 6.0|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_5_active_state: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_use_for_pos_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_invert_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_stop_at_max_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_axis_nr_steps_x: 0.0 => 6334|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_stop_at_max_x: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_secondary_motor_invert_x: 1.0 => 0|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_max_spd_z: 400.0 => 1500|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_keep_active_z: 1.0 => 0|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_3_active_state: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_enabled_y: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_min_spd_z: 50.0 => 200|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_missed_steps_max_z: 5.0 => 10|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_3_time_out: 0.0 => 60|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_4_active_state: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_stop_at_home_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: param_mov_nr_retry: 3.0 => 10|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_home_up_z: 1.0 => 0|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_2_active_state: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_enabled_x: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: param_e_stop_on_mov_err: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: encoder_scaling_z: 5556.0 => 1389|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_home_at_boot_x: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: pin_guard_1_time_out: 0.0 => 60|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_axis_nr_steps_y: 0.0 => 6386|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_stop_at_home_x: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_max_spd_x: 400.0 => 700|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_invert_motor_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_steps_acc_dec_z: 300.0 => 100|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Updating FW param: movement_home_at_boot_z: 0.0 => 1|0, 0, 0|Sep 24, 10:14pm|
|3
Success|Downloaded Farmware tools: https://api.github.com/repos/FarmBot-Labs/farmware-tools/releases/latest|0, 0, 0|Sep 24, 10:14pm|
|3
Busy|Downloading Farmware tools: https://api.github.com/repos/FarmBot-Labs/farmware-tools/releases/latest|0, 0, 0|Sep 24, 10:14pm|
|2
Success|Finishing install for #Farmware<camera-calibration(0.0.1)>|0, 0, 0|Sep 24, 10:14pm|
|2
Info|Checking directories for camera-calibration - 0.0.1|0, 0, 0|Sep 24, 10:14pm|
|2
Info|Starting preflight checks for #Farmware<camera-calibration(0.0.1)>|0, 0, 0|Sep 24, 10:14pm|
|2
Busy|Installing farmware from https://raw.githubusercontent.com/FarmBot-Labs/farmware_manifests/master/packages/camera-calibration/manifest.json.|0, 0, 0|Sep 24, 10:14pm|
|3
|3
|2
Success|Finishing install for #Farmware<plant-detection(0.0.4)>|0, 0, 0|Sep 24, 10:14pm|
|2
Info|Checking directories for plant-detection - 0.0.4|0, 0, 0|Sep 24, 10:14pm|
|2
Info|Starting preflight checks for #Farmware<plant-detection(0.0.4)>|0, 0, 0|Sep 24, 10:14pm|
|2
Busy|Installing farmware from https://raw.githubusercontent.com/FarmBot-Labs/farmware_manifests/master/packages/plant-detection/manifest.json.|0, 0, 0|Sep 24, 10:14pm|
|3
|3
|2
Success|Finishing install for #Farmware<historical-camera-calibration(0.0.1)>|0, 0, 0|Sep 24, 10:14pm|
|2
Info|Checking directories for historical-camera-calibration - 0.0.1|0, 0, 0|Sep 24, 10:14pm|
|2
Info|Starting preflight checks for #Farmware<historical-camera-calibration(0.0.1)>|0, 0, 0|Sep 24, 10:14pm|
|2
Busy|Installing farmware from https://raw.githubusercontent.com/FarmBot-Labs/farmware_manifests/master/packages/historical-camera-calibration/manifest.json.|0, 0, 0|Sep 24, 10:14pm|
|3
|3
|1
Busy|Initializing Firmware.|0, 0, 0|Sep 24, 10:14pm|
|1
Busy|Firmware not initialized yet. Waiting for R88 message.|Unknown|Sep 24, 10:14pm|
|2
Success|Finishing install for #Farmware<historical-plant-detection(0.0.1)>|Unknown|Sep 24, 10:14pm|
|2
Info|Checking directories for historical-plant-detection - 0.0.1|Unknown|Sep 24, 10:14pm|
|2
Info|Starting preflight checks for #Farmware<historical-plant-detection(0.0.1)>|Unknown|Sep 24, 10:14pm|
|2
Busy|Installing farmware from https://raw.githubusercontent.com/FarmBot-Labs/farmware_manifests/master/packages/historical-plant-detection/manifest.json.|Unknown|Sep 24, 10:14pm|
|2
Busy|Syncing all Farmware repos. This may take a while.|Unknown|Sep 24, 10:14pm|
|1
Success|Farmbot is up and running!|Unknown|Sep 24, 10:13pm|
|3
Success|Got ARDUINO STARTUP COMPLETE. UART is up.|Unknown|Sep 24, 10:13pm|
|2
Success|Successful Bootstrap authorization: bla@bla.de - https://my.farm.bot|Unknown|Sep 24, 10:12pm|
|1
Success|Connected to access point.|Unknown|Sep 24, 10:12pm|
|1
Warn|AuthTask not running yet|Unknown|Sep 24, 10:12pm|
|2
Busy|Beginning Bootstrap authorization: bla@bla.de - https://my.farm.bot|Unknown|Sep 24, 10:12pm|
|1
Error|Trying to resolve https://my.farm.bot 9 more times.|Unknown|Sep 24, 10:12pm|
|1
|1
|3
Success|Time seems to be set. Moving on.|Unknown|Sep 24, 10:12pm|
|3
Success|Interface wlan0 is up.|Unknown|Sep 24, 10:12pm|
|3
Busy|Waiting for interface wlan0 up.|Unknown|Sep 24, 10:12pm|
|3
Error|Error stopping dnsmasq: argument error|Unknown|Sep 24, 10:12pm|
|3
Busy|Killing dnsmasq PID.|Unknown|Sep 24, 10:12pm|
|3
Busy|Stopping dnsmasq|Unknown|Sep 24, 10:12pm|
|3
Busy|Stopping DHCP GenServer.|Unknown|Sep 24, 10:12pm|
|3
Busy|Stopping mDNS.|Unknown|Sep 24, 10:12pm|
|3
Busy|Stopping captive portal GenServer.|Unknown|Sep 24, 10:12pm|
|2
Success|Configuration finished.|Unknown|Sep 24, 10:12pm|
|1
Success|Firmware flashed! /srv/erlang/lib/farmbot-6.4.11/priv/arduino_firmware.hex|Unknown|Sep 24, 10:12pm|
|3
Busy|Starting avrdude: /srv/erlang/lib/farmbot-6.4.11/priv/arduino_firmware.hex|Unknown|Sep 24, 10:12pm|
|1
Success|Firmware flashed! /srv/erlang/lib/farmbot-6.4.11/priv/eeprom_clear.ino.hex|Unknown|Sep 24, 10:12pm|
|3
Busy|Starting avrdude: /srv/erlang/lib/farmbot-6.4.11/priv/eeprom_clear.ino.hex|Unknown|Sep 24, 10:12pm|
|1
Warn|Updating arduino firmware.|Unknown|Sep 24, 10:12pm|
|3
Busy|Starting captive portal.|Unknown|Sep 24, 10:08pm|
|3
Busy|Configuring Farmbot.|Unknown|Sep 24, 10:08pm|
|3
Success|detected target UART: /dev/ttyACM0|Unknown|Sep 24, 10:08pm|
|3
Busy|Checking /root/boot|Unknown|Sep 24, 10:07pm|
|1
Info|Loading kernel module: snd-bcm2835|Unknown|Sep 24, 10:07pm|
|1
Warn|Trying to emergency lock firmware before powerdown|0, 0, 0.67|Sep 24, 10:06pm|
|1
Warn|Going down for a reboot!|
Could you tell me what happened here? Why were I still able to control the bot but it seemed to be disconnected to the farmbot servers? There are too many strange things happening with these connectivity issues, really…
