Hi everyone
Upon turning on the farmbot, it doesn’t appear to be emitting wifi (can’t find the signal with farmbot name)
We did upgrade on December’s last OS version
Any ideas? I can’t configurate the internet connection…
Have a great day!
Coline
This often happens when the wrong version is flashed to the SD card. For example: attempting to flash the Express version of FBOS to a Genesis device.
The other problem we’ve seen is that sometimes the device will simply have a “bad flash” and needs to be re-flashed to fix accidental data corruption.
Can you please re-flash the SD card with the appropriate FBOS version (just to be 100% certain before proceeding) and then wait 5 minutes after that to see if the WiFi comes back.
Please let me know if a hard re-flash helps and we can go from there.
Please provide your device model and device ID in your reply.
