We have tried everything under the sun to get farmbot back online. We reflashed the OS (several times), changed wifi networks, moved the access point closer to the bot, even replaced the raspberry pi, and it still will not function. It continually boot loops and eventually gives up. Sometimes I can get it to home before it dies.
I’m not sure why, but your wifi network keeps dropping according to the logs you post. So it isn’t a server issue, but something with wifi. I use ethernet, fwiw.
It would help if you could share some more information. For example:
What’s your wifi setup like? How far is the FarmBot from the nearest access point? Is there any obstacle between the two? Are you using a fixed IP address (and if so, have you checked if another device is not connecting using the same IP), etc.?
Update:
Added a wifi repeater to get farmbot better signal, farmbot is no longer losing the network.
Farmbot now just bootloops and refuses to sync. Relative movements sometimes work.
Attempting to sync leads to http 429 errors. which I understand are too many request errors, so I turned off farmbot overnight and tried again this morning to no avail and got the same 429 errors
