Preferring to play with JavaScript on Ubuntu ( aarch64 / arm64 on Raspberry Pi ) I’ve learned that some adjustments are needed to have the whole thing work on this platform.
Using NPM package farmbot version 10.2.1 shows
fsevents is a Mac-specific package
ts-jest needs a specific ( earlier ) version of jest
Any thoughts on how I should address these ? ( maybe I can skip the unit testing bit _)
@jsimmonds Does FBJS not run on your machine? I find this surprising because I’ve actually never used FBJS on a mac machine. I have used it on an Xubuntu 18 machine for Node and Frontend work almost exclusively.
Also, the FBJS test suite has quite a bit of dust on it- I would not worry about it too much. It’s one of those libraries that rarely changes and rarely is the cause of production problems. As a result, I’ve been admittedly negligent in maintaining those parts of the lib.
FarmBot JS only deals with commands rather than resources. You would need to use an HTTP client for resource management.
I thought about adding resource management in the past but never got around to it (and realisticly don’t see myself having time in the next few months). In the interim, I would recomend:
Viewing our list of auto generated API responses for the sake of example (CTRL+F may be useful). It’s important to note that the examples are always correct because they are created using the test suite every time we run it. If you get errors, it may be an indication of a settings problem on the client side.
