my farmbot locks (e stop) itself in case movement fails 3 times. Is that correct behaviour if I have set E-Stop on Movement Error to Off? my settings are in the pic below.
I do get movement errors, but when I just retry the movement after error FB usually continues. Is there a way to pick up sequence from the point, where it stopped executing due to movement failure?
You are right, there should not be an e-stop with E-STOP ON MOVEMENT ERROR enabled in manual moving.
Please note, that movement errors that occurs while a sequence or a farmware is running would always cause an E-Stop, no matter what your E-STOP ON MOVEMENT ERROR setting is set.
This is not possible yet, but is on the future plan.
