I have two feature requests.
During a sequence, I would like to be able to zero the x, y, and z coordinates. After running a sequence 0, 0, 0 often changes slightly. If I instead end every sequence by running into the barriers slightly and then setting everything to zero, repeated sequences would be more reliable.
I would love to run sequences with parameters. Currently, when I run my plant seed sequence, I have to change the x, y for each seed I want planted. Supper tedious. Additionally, if I could run 10 sequences with a list of parameters, that would make planting 10 seeds as easy as planting 1.
