@Gabriel I installed my V-Wheels and plates today, they are too tight.
I adjusted the eccentric spacers for maximum distance and even that is very tight.
I will continue and see if the bot can move this amount of torque / fricition, do you
have any other solution if that does not work?
Edit: I fixed it, the tweak is to untighten the “fixed” wheels while the whole system
sits on the tracks (with the gantry installed, otherwise the added weight would make
one to redo later). By then tightening the fixed wheels again, the little tolerance in the
holes is enough to enable adjustment with the eccentric ones. By moving the gantry
for and aft a little, one can see wether the wheels are running correctly or if some of
them don´t make contact.
