I’m looking at farmbot system. My yard is mostly a gentle incline, probably 15% if I had to guess. Are there any issues with using the system tilted that much?
I have only seen installations on level ground. My guess is that the motors would struggle to pull FarmBot up any kind of incline.
A solution for you might be to grade the land, or build your raised bed/supporting infrastructure to be level on top for the FarmBot despite the inclined ground below.
Makes sense. Thanks!
