“invert jog buttons&display encoder data” setting resets to off
I constantly invert all 3 axis, and put the display encoder data on because is not saved.
I think this is a very small bug easy to fix.
Hi, these toggle switches do save your chosen setting. They are saved in LocalStorage
(in your web browser). So if you switch to another web browser, clear your browser cache, or use another device, then you will need to re-set the settings for that device. Eventually we will save your settings in the API so that they persist across devices and browser cache resets.
It is also possible we have a bug that I can’t reproduce. Which browser and operating system are you using?
