Hi Everyone,
Since last update of FarmbotOS (3.1.5) there is a possibility to set the axis limitation.
After I set the limitation ie. 2772mm and told bot to move to the end (2772mm) bot only moves to ie. 520mm.
Is this a glitch?
Hi Everyone,
Is this a glitch?
@connor I think the length limitation doesn’t use the steps/mm setting when sending the limit to the firmware.
You’d think they’d test their features before releasing them, wouldn’t you?
