Ive gotten though many issues getting farmbot connected. Ive had to resort to setting up Farmbot with the local server as the network i run farmbot with has a proxy and this can’t be circumnavigated due to been a school.
After i run sudo docker-compose up
everything seems to load then i get the below errors
Any assistance and explanation would be great. I’m assuming I’m missing something small at 330am…
> [17:15:09] Starting compilation in watch mode...
> typescript_1 |
> rabbit_jobs_1 | [SKYLIGHT] [3.1.4] Unable to start, see the Skylight logs for more details
> delayed_job_1 | [SKYLIGHT] [3.1.4] Unable to start, see the Skylight logs for more details
> delayed_job_1 | [Worker(host:05d5041f0b5f pid:1)] Starting job worker
> delayed_job_1 | 2019-03-01T17:15:10+0000: [Worker(host:05d5041f0b5f pid:1)] Starting job worker
> parcel_1 | [SKYLIGHT] [3.1.4] Unable to start, see the Skylight logs for more details
> parcel_1 | rm -rf .cache public/assets/parcel
> parcel_1 | node_modules/parcel-bundler/bin/cli.js watch frontend/css/_index.scss frontend/css/laptop_splash.scss frontend/entry.tsx frontend/front_page/index.tsx frontend/password_reset/index.tsx frontend/tos_update/index.tsx --out-dir public/assets/parcel --public-url /assets/parcel --no-hmr --no-cache --no-source-maps
> mqtt_1 | 2019-03-01 17:15:12.067 [info] <0.33.0> Application lager started on node rabbit@e64139784b1b
> rabbit_jobs_1 | Attempting to connect LogService to log_channel
> rabbit_jobs_1 | Attempting to connect Resources::Service to resource_channel
> rabbit_jobs_1 | W, [2019-03-01T17:15:17.451920 #1] WARN -- #<Bunny::Session:0x558a17133ed0 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Could not establish TCP connection to mqtt:5672: Connection refused - connect(2) for 172.18.0.6:5672
> rabbit_jobs_1 | Connecting to broker in 3 seconds.
> rabbit_jobs_1 | W, [2019-03-01T17:15:17.452497 #1] WARN -- #<Bunny::Session:0x558a171316d0 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Could not establish TCP connection to mqtt:5672: Connection refused - connect(2) for 172.18.0.6:5672
> mqtt_1 | 2019-03-01 17:15:18.840 [info] <0.33.0> Application mnesia started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.841 [info] <0.33.0> Application crypto started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.841 [info] <0.33.0> Application jsx started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.841 [info] <0.33.0> Application xmerl started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.841 [info] <0.33.0> Application os_mon started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.842 [info] <0.33.0> Application inets started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.842 [info] <0.33.0> Application cowlib started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.842 [info] <0.33.0> Application asn1 started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.842 [info] <0.33.0> Application public_key started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.842 [info] <0.33.0> Application ssl started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.842 [info] <0.33.0> Application ranch started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.858 [info] <0.33.0> Application cowboy started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.858 [info] <0.33.0> Application ranch_proxy_protocol started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.858 [info] <0.33.0> Application recon started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.858 [info] <0.33.0> Application rabbit_common started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.867 [info] <0.33.0> Application amqp_client started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:18.869 [info] <0.240.0>
> mqtt_1 | Starting RabbitMQ 3.7.6 on Erlang 20.3.8
> mqtt_1 | Copyright (C) 2007-2018 Pivotal Software, Inc.
> mqtt_1 | Licensed under the MPL. See http://www.rabbitmq.com/
> mqtt_1 |
> mqtt_1 | ## ##
> mqtt_1 | ## ## RabbitMQ 3.7.6. Copyright (C) 2007-2018 Pivotal Software, Inc.
> mqtt_1 | ########## Licensed under the MPL. See http://www.rabbitmq.com/
> mqtt_1 | ###### ##
> mqtt_1 | ########## Logs: <stdout>
> mqtt_1 |
> mqtt_1 | Starting broker...
> mqtt_1 | 2019-03-01 17:15:18.870 [info] <0.240.0>
> mqtt_1 | node : rabbit@e64139784b1b
> mqtt_1 | home dir : /var/lib/rabbitmq
> mqtt_1 | config file(s) : /farmbot/farmbot_rmq_config.conf
> mqtt_1 | cookie hash : KmTeCcfHRrW0D+gK+vuTow==
> mqtt_1 | log(s) : <stdout>
> mqtt_1 | database dir : /var/lib/rabbitmq/mnesia/rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.181 [info] <0.287.0> Memory high watermark set to 3133 MiB (3285273804 bytes) of 7832 MiB (8213184512 bytes) total
> mqtt_1 | 2019-03-01 17:15:20.225 [info] <0.289.0> Enabling free disk space monitoring
> mqtt_1 | 2019-03-01 17:15:20.225 [info] <0.289.0> Disk free limit set to 50MB
> mqtt_1 | 2019-03-01 17:15:20.237 [info] <0.292.0> FHC read buffering: OFF
> mqtt_1 | 2019-03-01 17:15:20.237 [info] <0.292.0> FHC write buffering: ON
> mqtt_1 | 2019-03-01 17:15:20.237 [info] <0.291.0> Limiting to approx 1048476 file handles (943626 sockets)
> mqtt_1 | 2019-03-01 17:15:20.240 [info] <0.240.0> Waiting for Mnesia tables for 30000 ms, 9 retries left
> rabbit_jobs_1 | W, [2019-03-01T17:15:20.453356 #1] WARN -- #<Bunny::Session:0x558a171363d8 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Could not establish TCP connection to mqtt:5672: Connection refused - connect(2) for 172.18.0.6:5672
> rabbit_jobs_1 | W, [2019-03-01T17:15:20.453512 #1] WARN -- #<Bunny::Session:0x558a17134970 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Could not establish TCP connection to mqtt:5672: Connection refused - connect(2) for 172.18.0.6:5672
> mqtt_1 | 2019-03-01 17:15:20.459 [info] <0.240.0> Waiting for Mnesia tables for 30000 ms, 9 retries left
> mqtt_1 | 2019-03-01 17:15:20.459 [info] <0.240.0> Peer discovery backend rabbit_peer_discovery_classic_config does not support registration, skipping registration.
> mqtt_1 | 2019-03-01 17:15:20.460 [info] <0.240.0> Priority queues enabled, real BQ is rabbit_variable_queue
> mqtt_1 | 2019-03-01 17:15:20.489 [info] <0.314.0> Starting rabbit_node_monitor
> mqtt_1 | 2019-03-01 17:15:20.557 [info] <0.240.0> Management plugin: using rates mode 'basic'
> mqtt_1 | 2019-03-01 17:15:20.559 [info] <0.346.0> Making sure data directory '/var/lib/rabbitmq/mnesia/rabbit@e64139784b1b/msg_stores/vhosts/628WB79CIFDYO9LJI6DKMI09L' for vhost '/' exists
> mqtt_1 | 2019-03-01 17:15:20.589 [info] <0.346.0> Starting message stores for vhost '/'
> mqtt_1 | 2019-03-01 17:15:20.590 [info] <0.350.0> Message store "628WB79CIFDYO9LJI6DKMI09L/msg_store_transient": using rabbit_msg_store_ets_index to provide index
> mqtt_1 | 2019-03-01 17:15:20.592 [info] <0.346.0> Started message store of type transient for vhost '/'
> mqtt_1 | 2019-03-01 17:15:20.592 [info] <0.353.0> Message store "628WB79CIFDYO9LJI6DKMI09L/msg_store_persistent": using rabbit_msg_store_ets_index to provide index
> mqtt_1 | 2019-03-01 17:15:20.599 [info] <0.346.0> Started message store of type persistent for vhost '/'
> mqtt_1 | 2019-03-01 17:15:20.606 [info] <0.388.0> started TCP Listener on [::]:5672
> mqtt_1 | 2019-03-01 17:15:20.607 [info] <0.240.0> Setting up a table for connection tracking on this node: tracked_connection_on_node_rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.607 [info] <0.240.0> Setting up a table for per-vhost connection counting on this node: tracked_connection_per_vhost_on_node_rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.608 [info] <0.33.0> Application rabbit started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.608 [info] <0.33.0> Application rabbitmq_auth_backend_http started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.630 [info] <0.33.0> Application rabbitmq_auth_backend_cache started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.648 [info] <0.33.0> Application rabbitmq_management_agent started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.649 [info] <0.445.0> MQTT retained message store: rabbit_mqtt_retained_msg_store_dets
> mqtt_1 | 2019-03-01 17:15:20.651 [info] <0.463.0> started MQTT TCP Listener on [::]:1883
> mqtt_1 | 2019-03-01 17:15:20.651 [info] <0.33.0> Application rabbitmq_mqtt started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.655 [info] <0.466.0> rabbit_web_mqtt: listening for HTTP connections on undefined:15675
> mqtt_1 | 2019-03-01 17:15:20.655 [info] <0.33.0> Application rabbitmq_web_mqtt started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.656 [info] <0.33.0> Application rabbitmq_web_dispatch started on node rabbit@e64139784b1b
> mqtt_1 | 2019-03-01 17:15:20.721 [info] <0.489.0> Management plugin started. Port: 15672
> mqtt_1 | 2019-03-01 17:15:20.721 [info] <0.595.0> Statistics database started.
> mqtt_1 | 2019-03-01 17:15:20.722 [info] <0.33.0> Application rabbitmq_management started on node rabbit@e64139784b1b
> mqtt_1 | completed with 7 plugins.
> mqtt_1 | 2019-03-01 17:15:21.028 [info] <0.5.0> Server startup complete; 7 plugins started.
> mqtt_1 | * rabbitmq_management
> mqtt_1 | * rabbitmq_web_dispatch
> mqtt_1 | * rabbitmq_web_mqtt
> mqtt_1 | * rabbitmq_mqtt
> mqtt_1 | * rabbitmq_management_agent
> mqtt_1 | * rabbitmq_auth_backend_cache
> mqtt_1 | * rabbitmq_auth_backend_http
> mqtt_1 | 2019-03-01 17:15:23.455 [info] <0.605.0> accepting AMQP connection <0.605.0> (172.18.0.7:60020 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:23.455 [info] <0.608.0> accepting AMQP connection <0.608.0> (172.18.0.7:60022 -> 172.18.0.6:5672)
> rabbit_jobs_1 | E, [2019-03-01T17:15:23.458991 #1] ERROR -- #<Bunny::Session:0x558a17141760 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> rabbit_jobs_1 | E, [2019-03-01T17:15:23.459315 #1] ERROR -- #<Bunny::Session:0x558a1714b7d8 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:23.458 [error] <0.608.0> Error on AMQP connection <0.608.0> (172.18.0.7:60022 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | PLAIN login refused: rabbit_auth_backend_cache failed authenticating admin: {failed_connect,
> mqtt_1 | [{to_address,
> mqtt_1 | {"localhost",3000}},
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 | econnrefused}]}
> mqtt_1 |
> mqtt_1 | 2019-03-01 17:15:23.458 [error] <0.605.0> Error on AMQP connection <0.605.0> (172.18.0.7:60020 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> mqtt_1 | 2019-03-01 17:15:26.459 [info] <0.608.0> closing AMQP connection <0.608.0> (172.18.0.7:60022 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:26.460 [info] <0.605.0> closing AMQP connection <0.605.0> (172.18.0.7:60020 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:26.461 [info] <0.615.0> accepting AMQP connection <0.615.0> (172.18.0.7:60030 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:26.462 [info] <0.618.0> accepting AMQP connection <0.618.0> (172.18.0.7:60032 -> 172.18.0.6:5672)
> rabbit_jobs_1 | E, [2019-03-01T17:15:26.465510 #1] ERROR -- #<Bunny::Session:0x558a17160408 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:26.465 [error] <0.618.0> Error on AMQP connection <0.618.0> (172.18.0.7:60032 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> mqtt_1 | 2019-03-01 17:15:26.465 [error] <0.615.0> Error on AMQP connection <0.615.0> (172.18.0.7:60030 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> rabbit_jobs_1 | E, [2019-03-01T17:15:26.468234 #1] ERROR -- #<Bunny::Session:0x558a17176cf8 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:29.466 [info] <0.618.0> closing AMQP connection <0.618.0> (172.18.0.7:60032 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:29.466 [info] <0.615.0> closing AMQP connection <0.615.0> (172.18.0.7:60030 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:29.471 [info] <0.625.0> accepting AMQP connection <0.625.0> (172.18.0.7:60034 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:29.472 [info] <0.628.0> accepting AMQP connection <0.628.0> (172.18.0.7:60036 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:29.474 [error] <0.625.0> Error on AMQP connection <0.625.0> (172.18.0.7:60034 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> rabbit_jobs_1 | E, [2019-03-01T17:15:29.476232 #1] ERROR -- #<Bunny::Session:0x558a17181c98 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:29.477 [error] <0.628.0> Error on AMQP connection <0.628.0> (172.18.0.7:60036 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> rabbit_jobs_1 | E, [2019-03-01T17:15:29.478135 #1] ERROR -- #<Bunny::Session:0x558a17187648 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:32.476 [info] <0.625.0> closing AMQP connection <0.625.0> (172.18.0.7:60034 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:32.479 [info] <0.628.0> closing AMQP connection <0.628.0> (172.18.0.7:60036 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:32.479 [info] <0.634.0> accepting AMQP connection <0.634.0> (172.18.0.7:60038 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:32.483 [info] <0.638.0> accepting AMQP connection <0.638.0> (172.18.0.7:60040 -> 172.18.0.6:5672)
> rabbit_jobs_1 | E, [2019-03-01T17:15:32.486770 #1] ERROR -- #<Bunny::Session:0x558a1719c8e0 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:32.486 [error] <0.638.0> Error on AMQP connection <0.638.0> (172.18.0.7:60040 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> mqtt_1 | 2019-03-01 17:15:32.486 [error] <0.634.0> Error on AMQP connection <0.634.0> (172.18.0.7:60038 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> rabbit_jobs_1 | E, [2019-03-01T17:15:32.489766 #1] ERROR -- #<Bunny::Session:0x558a171b2c58 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:35.487 [info] <0.634.0> closing AMQP connection <0.634.0> (172.18.0.7:60038 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:35.487 [info] <0.638.0> closing AMQP connection <0.638.0> (172.18.0.7:60040 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:35.491 [info] <0.645.0> accepting AMQP connection <0.645.0> (172.18.0.7:60042 -> 172.18.0.6:5672)
> rabbit_jobs_1 | E, [2019-03-01T17:15:35.497391 #1] ERROR -- #<Bunny::Session:0x558a171d3ca0 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:35.495 [error] <0.645.0> Error on AMQP connection <0.645.0> (172.18.0.7:60042 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> mqtt_1 | 2019-03-01 17:15:35.497 [info] <0.649.0> accepting AMQP connection <0.649.0> (172.18.0.7:60044 -> 172.18.0.6:5672)
> rabbit_jobs_1 | E, [2019-03-01T17:15:35.500921 #1] ERROR -- #<Bunny::Session:0x558a171d1a68 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:35.500 [error] <0.649.0> Error on AMQP connection <0.649.0> (172.18.0.7:60044 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> mqtt_1 | 2019-03-01 17:15:38.496 [info] <0.645.0> closing AMQP connection <0.645.0> (172.18.0.7:60042 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:38.502 [info] <0.649.0> closing AMQP connection <0.649.0> (172.18.0.7:60044 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:38.506 [info] <0.655.0> accepting AMQP connection <0.655.0> (172.18.0.7:60046 -> 172.18.0.6:5672)
> mqtt_1 | 2019-03-01 17:15:38.506 [info] <0.658.0> accepting AMQP connection <0.658.0> (172.18.0.7:60048 -> 172.18.0.6:5672)
> rabbit_jobs_1 | E, [2019-03-01T17:15:38.509679 #1] ERROR -- #<Bunny::Session:0x558a171e9168 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:38.510 [error] <0.658.0> Error on AMQP connection <0.658.0> (172.18.0.7:60048 -> 172.18.0.6:5672, state: starting):
> mqtt_1 | {inet,
> mqtt_1 | [inet],
> mqtt_1 |
> rabbit_jobs_1 | E, [2019-03-01T17:15:38.525647 #1] ERROR -- #<Bunny::Session:0x558a171eae50 admin@mqtt:5672, vhost=/, addresses=[mqtt:5672]>: Authentication with RabbitMQ failed: 403 ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
> mqtt_1 | 2019-03-01 17:15:38.526 [error] <0.655.0> Error on AMQP connection <0.655.0> (172.18.0.7:60046 -> 172.18.0.6:5672, state: starting):
