I changed my Wifi details and so ran the configurator again.
On restart I no longer have the custom farmware I’d installed, and although I see the titles of the sequences I’d built the actual sequences have gone.
Not a big problem at this stage as I’m just playing around, but is this the expected behavior?
How did you do that? Factory reset or reflashed the sd-card?
Farmwares should persist through restarts since they are saved on the sd-card (OS). Also all sequences should not be affected by the device since they are saved in the WebApp (API) and will be synced when the device is connected.
