# Lua sequence block questions
**URL:** <https://forum.farmbot.org/t/lua-sequence-block-questions/7661>\
**Category:** Software Development\
**Created:** [July 26, 2021, 4:53pm UTC](https://forum.farmbot.org/t/lua-sequence-block-questions/7661 "2021-07-26T16:53:57Z")\
**Posts on this page:** 1\
**Showing post:** 6
<div class="post-metadata">
**Author:** ![Deisengard](https://forum.farmbot.org/letter_avatar_proxy/v4/letter/d/dec6dc/32.png) [@Deisengard](https://forum.farmbot.org/u/Deisengard)\
**Post date:** [July 29, 2021, 1:16am UTC](https://forum.farmbot.org/t/lua-sequence-block-questions/7661/6 "2021-07-29T01:16:22Z")
</div>
Thanks again for your feedback! It sounds like we’re on a reasonable path. I’ll be happy to share as we work out the details!
I want to test the events, sequences and Lua code without being connected to our actual machine, so I am working on setting up a test platform for this using an RPi3 and Arduino Mega as described [elsewhere on this forum](https://forum.farmbot.org/t/farmbotos-rpi0-without-farmduino/6883). I’ve got it connected to the web app. When it comes to setup, can I answer yes to all the motor/movement related questions in the wizard and expect to be able to simulate the operation of the machine in a meaningful way? Right now if I attempt to jog the gantry it always jumps back home after animating the movement. Are there any steps I need to take for the web app to think the movements have completed? Or am I missing something?
EDIT: I think maybe I’ll answer my own question again. Looks like turning off the encoders did the trick.
_[View the full topic](https://forum.farmbot.org/t/lua-sequence-block-questions/7661)._
