I have the mqtt connection working with node-red. When i sent a comment its possible to sent a label with the command. I want to use the logs to check of a action is successful finished. But in the logs i don’t see the label so i can’t related them easily based on the label. Is there a way to make the label visible in the mqtt logs or is there some other reference id?
Yes but this is the message of the request was succesfull. I mean /logs message that’s comes back. This shows the real result after processing if i’m right? Here i see no labels.
Currently the only response message that includes the RPC label is the RPC response. Log messages will not include the RPC label, but that is a feature we will consider adding in the future.
