I experienced now several times that the bot disconnects from some service (?) during a sequence execution. This is clearly shown as disconnect in the web frontend. Mostly after some minutes its back on again. It is NOT the WiFi connection as you can see below in the screenshot, no station disconnected from WiFi during this time.
@Gabriel @connor please help! Latest FW versions…
Success Synced 69, 200, 100 May 31, 8:00am
2Busy Syncing 69, 200, 100 May 31, 8:00am
3Success Farmbot was reconnected to the internet: [‘my.farmbot.io’] 69, 200, 100 May 31, 8:00am
3Warn Farmbot was disconnected from the internet: :timeout 69, 200, 100 May 31, 8:00am
1Busy Moving to (70.0, 200.0, 100.0) 70, 200, 252 May 31, 7:57am
2Info [Water Sensor mount 2/2] - Sequence Executing: MoveAbsolute 70, 200, 252 May 31, 7:57am
1Success Movement to (70.0, 200.0, 252.0) complete. 70, 200, 252 May 31, 7:57am
1Busy Moving to (70.0, 200.0, 252.0) 0, 200, 252 May 31, 7:57am
2Info [Water Sensor mount 2/2] - Sequence Executing: MoveAbsolute 0, 200, 252 May 31, 7:57am
1Success Movement to (0.0, 200.0, 252.0) complete. 0, 200, 252 May 31, 7:57am
