can anybody help me
i can’t log in on the main page ‘my.farmbot.io’ the button to log in or create don’t work
same problem on ‘staging.farmbot.io’
i need to manualy type in the browser field ‘staging.farmbot.io/app/login’ then i can log in but it seems to be
that not all functions work i can’t put in a divice name or UUID
nor i can save the steps per mm or lenght
{“params”:{“x”:0,“y”:0,“z”:0,“s”:10,“busy”:1,“last”:“none”,“movement_max_spd_x”:10,“movement_max_spd_y”:10,“movement_max_spd_z”:1 0,“pin0”:“unknown”,“pin1”:“unknown”,“pin2”:“unknown”,“pin3”:“unknown”,“pin4”:“unknown”,“pin5”:“unknown”,“pin6”:“unknown”,“pin7”:" unknown",“pin8”:“unknown”,“pin9”:“unknown”,“pin10”:“unknown”,“pin11”:“unknown”,“pin12”:“unknown”,“pin13”:“unknown”,“last_sync”:“2 016-08-11T21:17:44.079+00:00”,“movement_steps_acc_dec_x”:10,“movement_steps_acc_dec_y”:10,“movement_steps_acc_dec_z”:10,“method”: “calibrate_axis”,“movement_timeout_x”:10,“movement_timeout_y”:10,“movement_timeout_z”:10,“movement_axis_nr_steps_x”:“1”,“movement _axis_nr_steps_y”:“1”,“movement_axis_nr_steps_z”:“1”},“method”:“update_calibration”,“id”:“8f82644d-322c-48a7-aaa1-1f4b6d0ab68b”}
