Hi everyone,
I’m having trouble connecting the Raspberry Pi to the Farmduino. After successfully setting up the network, it’s showing the code 30 error.
I tried clicking the buttons corresponding to flashing and restarting the Farmduino firmware respectively, but that is also returning an error. I tired manually flashing the firmware using the Arduino IDE , but a time out error occurs while uploading the script to the Farmduino.
I tried following the steps given in the website to resolve the code 30 error, but to no avail.
I would really appreciate if someone could help me out on this.
So I have tried restarting the firmware, verifying the I/O cables, flashing the firmware as well even tried uploading the firmware from Arduino IDE but no luck.
But later on, we had another Farmbot running and we swapped the Farmduino and it worked like charm and tried that Farmduino on another Farmbot it didn’t work.
One more thing, FarmBot doesn’t connect to the setup or configurator with that Farmduino but works with another Farmdunio and keeps showing this error: " Farmbot_ext exited 5: : shutdown "
@DAA I am so sorry- it appears you have found a bug in FBOS v14 that is unrelated to your original issue. Thank you for reporting this- I will fix it and publish FBOS v14.0.1 shortly.
I have temporarily fixed your device, but unfortunately, until v14.0.1 is released, the problem will return when you reboot. You can temporarily work around the problem by leaving your device running (firmware currently works).
This problem is my top priority today and I hope to have a permanent fix soon.
