got a new farmdunio 1.4v the other day to replace a doa farmdunio.
i can manually move it using controls page. but every time i get a error saying relative movement failed on all 3 axes.
motor coordinates(mm) and scaled encoder(mm) show 0 all the time and raw encoder data shows -1
i turned off power to the motors and moved them by hand to see if any of the motor coordinates or others changed but nothing changes.
sorry i havent gotten back in months!! wether got crap then got busy at work and other projects.
i atempted to run the farmbot again. i reinstalled the firmware again 1.4v farmduino. can jog all moters ether way. (z is quite loud) checked the voltage at the output from the board and at the input to the encoder around 5.05Vdc. shows as -1 in raw data and if i flip it on the webpage it goes to 1. but it never moves when i move it by hand or jog it via app. everything else that i have tested so far works as it should. any ideas how to foult find this issue?
If movements complete successfully with encoders disabled on a v1.4 Farmduino, then the correct firmware has been selected and the issue is restricted to encoder position reporting. However, if the encoders are unplugged or not reporting to the Farmduino, the raw encoder position values should read 0. -1 can indicate an error internal to the Farmduino, which a power cycle usually resolves. Can you try installing and running this Farmware to reset encoder tracking and check if the raw encoder position values report 0?
i have reflashed the farmduino. still getting -1 on all 3.
tryied the farmware to reset encoder tracking. still shows -1.
i have spare pi3’s and arduinos so i can test the encoders if someone tells me which file to load and the pinout to use to test the encoders.
If the raw encoder positions still show -1 after the tracking reset with the encoders unplugged, it’s likely the issue is with the Farmduino rather than the encoders.
If you do want to test the encoders, you could load FarmBot OS on a Raspberry Pi connected to an Arduino Mega and select Arduino/RAMPS (Genesis v1.2) for the firmware during configuration. The encoders can then be attached to any of the following pins for testing (in addition to 5v and ground):
just did the test with the arduino/pi3 with farmbot os. its reading the encoders fine
already had a doa farmduino 1.4 board and got replaced with the board and its not working ether
