I’m having a lot of issues with odd behavior when running sequences. Many of my sequences begin with a move up 100 steps if z > 100, followed by FIND HOME. FB will move up 100, then perform HOME Z, followed by HOME Y, and then stop with the following error:
If I run the sequence a second time it skips the move up since z < 100, performs HOME Z, followed by HOME Y, followed by HOME X, and then completes running the rest of the sequence.
I’m still having this problem. The failure occurs when the FIND HOME command runs. It occurs after HOME Y initiates movement. Do these error codes have any meaning?
Hmm ok so, R04 seems to be an issue when the FB is running the command, is there a particular place that this error comes up at within the sequence? it seems that the error is happening with a move command based on the error you provided.
with the Q26 code. im not exactly sure. it says Queue number but i dont have a clue wat it could be queueing up.
@connor might have a better answer for you on this one.
The error occurs when I execute FIND HOME in a sequence. Normally, when FIND HOME is executed in a sequence Farmbot performs a HOME Z, followed by HOME Y, and ends with HOME X. The error occurs after HOME Y is executed. The HOME Y command completes but HOME X never happens.
This happens in every sequence that begins with executing FIND HOME. It happens when a sequence calls another sequence that begins with FIND HOME. Rerunning the sequence is almost always successful.
Here’s a video showing this happening for mine as well. Running Find Home all stops running after the Y sequence, X never starts. However, when I find home or re-run the sequence after its reached this state, you can hear Z and Y home correctly, then X will start. Curiously, the Find Home action at the end of the same sequence always seems to run correctly.
