hi @roryaronson, I even leave the soil sensor in the same location without moving it. Then I read the sensor every 5 secs and I get the full range of values between 200 and 1020 up and down and up again,
So for me, I dont get any useful values from the sensor.
Our Genesis v1.5 kits include a custom soil sensor PCB that measures soil moisture in the same way as the SparkFun ones used before. The new PCB also has a temperature sensor which can be read over I2C, though we donât have firmware support for it yet.
Hi @JoeHou, @qurzschluss
I followed your thread and installed the farmware âSet Pin IO Modeâ. I did a sequence that sets the pin 59 to Input:0.
But still my values are always very similar, between 890 and 905, independently if in air or in waterâŚ
I use a capactive sensor like you do, and I am not a sklĂlled hardware guy (more software ), could you give me some hints what I can do to find out if and how i get my capacitive soil sensor working properly?
Thanks in advance
Markus
Just remember that you canât use the whole resolution of 0V-5V (0-1023) of your input pins as these capacitive sensors output is officially only 0-3V. Measuring completely dry soil (3V- 3.3V) should get you values from 613 to 675 while measuring in water (1,5V) should be like 306.
