Hi everyone! I am a Latvian student, who working with farmbot, and I have some problems. After giving a commands, it’s just disconecct and show CORRUPT ECHO error, or smth with firmware. Maybe someone can give an advice what to do?
Hi @kpejsnieks
That error comes from farmbot_os running on the Raspberry Pi.
Every command string sent to the Arduino firmware on the Farmduino is transmitted back to farmbot_os for literal verification.
The serial connection between the Raspberry Pi Zero 2 W and the Farmduino Express is over short PCB traces and via the 40 pin header connectors.
Check that the Raspberry Pi board is seating correctly into the Farmduino.
Otherwise please give more detail, e.g. where do you observe the CORRUPT ECHO error ? and does this error occur for every Command sent to the Farmduino ? . . .etcetera
Hi @jsimmonds
As I checked, the connection is alright. More about error: I started working with farmbot 3 years ago and there was lot of problems, that now is gone, it was movements problems, now while I choose, for example, go to the x axis 1000 mm, it will go all 1000, but when I choose maximum lengths, which is 2000(it is shorter, because of modification) it will go only 1982 or 1992. And shows corrupt echo, or without even starting to move, the same error will appear.
Hi @kpejsnieks
Try asking FarmBot Inc. directly about this issue
Contact us today
