I saw that you can set a speed in the sequencer “move to absolute position”.
Does that overwrite the max speed you can set in the device menu?
Cheers
Cheers
Hey Klimbim
I tried that in various ways but wasn’t successful at all. I guess this would need a fix if its even implemented at all
For what i’ve expected, this option would set the speed that is used to get to the desired position for every axis. So its just the speed for this one operation.
That setting has had some issues at the firmware level for some time. We’re going to rewrite it and most likely change it to be a percentage of maximum speed, with the default being 100. For now, the Arduino will not respect the speed value.
