The STL file for "Soil Sensor Mount" is missing from the documentation
Hi,
We are trying to follow the list of plans, continue to print out one by one parts. But found that the document “Soil Sensor Mount” STL file is missing, please add it in the document.
Thank you very much!
Sorry about not making this clear. As of v1.1, we have moved our entire CAD workflow to Onshape (read more here: https://farmbot.io/2016/10/12/farmbot-meet-onshape/), which is a publicly available cloud-based CAD system. This means that you can go in and view the native CAD files/assemblies/drawings, and even copy them to modify on your own if you want. If you click the link below you will find the soil sensor part. Right click the part and press “Export” to export as an .STL or other common CAD formats. https://cad.onshape.com/documents/6626b842adca229e69544ad1/w/89ac2637f82d915f22c2bcd0/e/c51e329113118783fb95d370
