Understanding log output - Warning = “Got idle while executing a command“
I am trying to figure out why I get the following “Warning” in my log output:
“Got idle while executing a command”
It does not seem to cause any unintentional action, nor does it seem to reflect any observable “fail”
I would like to know what causes it.
Thanks!
As I see it, this is a side-effect of the Firmware's (MCU/Farmduino/RAMPS) async. conversation with the FarmBot OS on the Raspberry Pi, and, as you noted, not an issue, but seems to be some sort of Developer Diagnostic :slight_smile:
[ I stand to be corrected by a certified FarmBot Dev. e.g. @Gabriel ]
Thanks for the info, John!
Good to hear agreement that you too feel it is benign.
