# UTM Pin connectivity issues
**URL:** <https://forum.farmbot.org/t/utm-pin-connectivity-issues/8841>\
**Category:** Hardware\
**Created:** [November 27, 2023, 2:16am UTC](https://forum.farmbot.org/t/utm-pin-connectivity-issues/8841 "2023-11-27T02:16:03Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![Marc](https://forum.farmbot.org/user_avatar/forum.farmbot.org/marc/32/3545_2.png) [@Marc](https://forum.farmbot.org/u/Marc)\
**Post date:** [November 27, 2023, 5:30pm UTC](https://forum.farmbot.org/t/utm-pin-connectivity-issues/8841/2 "2023-11-27T17:30:27Z")
</div>
Hello,
Would you be able to create a video of your mounting process and zoom in to the Universal Tool Mount? We would need to see exactly what is happening to your FarmBot.
Alternatively, you can 3D print the hard mounted watering nozzle:
> [@Separate water nozzle (no need to Mount) / Improved water flow](https://forum.farmbot.org/t/separate-water-nozzle-no-need-to-mount-improved-water-flow/6550):
> I have posted an alternative water nozzle on Thingiverse: [https://www.thingiverse.com/thing:4534979](https://www.thingiverse.com/thing:4534979) It has solved two issues and created one additional benefit for me: Rather than droplets, the original watering tool on my FBot creates a devastating water column of death (water pressure not high enough?). The new tool has less holes and they are printed at different angles, hence resulting in a cone of droplets: ORIGINAL ALTERNATIVE DESIGN I have lots of …
 ![image](https://forum.farmbot.org/uploads/default/original/2X/d/d13f74cdb89416a7f84c1412b0cd1e2dba669cf3.jpeg)
This watering nozzle would negate the need to mount and dismount tools.
Marc
_[View the full topic](https://forum.farmbot.org/t/utm-pin-connectivity-issues/8841)._
