looks like there might be a little mistake in the update process at least for me. When I try to update the OS from 6.4.13 to 7.0.0 via update button, the following messages appear and the update process is aborted.
I’m using a raspberry pi 3b+ but that wasn’t a problem lately.
Tried rebooting for a few times, does not seem to work. It was working in the previous versions, so I’ll check my network settings and maybe even flash different versions to find out if something changed on my side.
I reflashed the SD card and noticed while configurating, that my 5Ghz WiFi wasn’t working properly anymore and always crashed while connecting. So I connected to 2.4Ghz and updated to v7.0.0. One of those seem to have fixed the issue for me.
Here is the node name if it still helps you in any way:
