After I first calibrated, I can get the tool and get it back correctly. But when I let farmbot set the sequence to automatically get the tools and water, the tool will always drop. Or pour the water back when the automatic return tool, the same action but he can not go back, always knocked out. Or even return to the correct coordinates?
浇水器归还准备(Ready to return the watering device)
浇水(water)
There are examples of tool mounting sequences in the software documentation. I would recommend using a single tool location and offsets, as explained in the documentation. You may also want to try to create a mounting tool sequence and run it using an execute sequence step, which is also shown in the documentation.
i have try!
