Is there a pin map for the ramps shield for which motor goes where, and where the vacuum gets hooked up, and the solenoid valve. I remember there used to be one in the docs, but I can’t seem to find it, but I have a FarmBot assembled, I just have to toss the electronics on there and this is the only thing holding me back.
Hey David, you will plug your motors into the X, Y, and Z slots on the RAMPS shield. The vacuum pump and solenoid valve should be hooked up to D8, D9, and D10 (your choice). We’re going to have a customizable peripherals widget on the web app out next week, so you will be able to control/label them manually with that widget, or you can do so from the sequences
I have a Genesis 1.2 that I cannot get to move on any axis. I can see that the Motor cables are connected correctly but I believe the encoder cables are not. In this version, the encoder cables had individual connectors for each wire. I can see from the response from Gabriel what each pin on the Arudino are for but I don’t know which wire is for which function. Do you have the color code for the encoder cables?
