Hi farmbot team,
(I use the old arduno/Ramps electronics.)
As discussed in other threads, the pullup resistors on analog inputs do not make much sense and tend to make trouble with new tools (capacitive soil moisture, distance, etc.). In the webapp under “control/sensors” there is already the option “digital”, “analog”.
I suggest introducing “analog no pullup”. There is a G Code Command to switch off pullups in arduino firmware. Therefore this feature would be implemented straight forward, I think. It would solve compiling custom arduino firmware to get rid of the pullup temporariliy, as suggested in another thread.
Greetings and thanks for the great work,
Georg (qurzschluss)
@JoeHou I can add this to a new release for you to try. I can’t do an official release because we need to do QA and update documentation first, but it is available as a pre-release on the FarmBot OS releases page
Please try it out and let me know if it works for you. I’m happy to make updates to the Lua sandbox as needed to accommodate the needs of former Farmware authors (with some limitations).
Hi RickCarlino,
Awesome!! thank you very much for your quick reply, this is the feature I want, everything is working fine in the test function so far!!!
